跳转到主内容
修复你的物品
维修的权力
商店
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2418 个问题 查看全部
Yellow color merges on the top screen
i noticed yellow color spot on the top on my iphone 6s...please help thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个回答
shoulds like an lcd problem, maybe need to replace it
这个答案有帮助吗?
得分 0
添加一条评论
Has it been recently replaced?
If so, sounds like the metal Sheild on the flex maybe too high/low pushing pressure on the lcd.
Is the yellowing large, or small?
这个答案有帮助吗?
得分 0
添加一条评论
A Yellow dot is typical on poor quality backlights on replaced screens. If you have not had a replacement screen and the screen you have is the original one another possibility is that if the phone has received a blow (typically from a drop ) it may well have created a small dent that has placed the screen under pressure thus in turn placing the backlight under slight pressure and that is showing through with a yellow patch.
An easy way is just to connect a replacement screen but dont seat it back in place. Boot the iPhone and see if the yellow patch is gone if it has then power down and disconnect the battery and screen again. Then examine the housing any even tiny dents etc can cause the issue. If you dont have the tools to remove those dents its quite cheap to get a new housing
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
hina 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 13
过去的30天: 91
总计 4,787
