跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
999 个问题 查看全部
I dropped my phone off to get looked at and it isn't working now.
I dropped my phone off at an apple store to get it looked at to make sure nothing was wrong with it and I just got it back and it isn't turning on so I obviously I thought it was dead so I plugged it in and it still won't turn on. (Yes I know I need a new phone if it is having this many problems.)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
8条评论
what was wrong with it that you needed to take it to the apple store
完成的
I dropped it in water 2 months ago and it is starting to overheat, battery expanding, turns itself off, and dying even when charging.
完成的
did the apple store say they repaired it
完成的
They told me all was good and I payed and left. They didn't give me my phone till after I paid and now I know why.
完成的
apple store doesnt fix water damaged phones so obviously they didnt do anything. better sending it to ipad rehab or sts telecom. im sure jessa or jason could sort it out
完成的
显示更多的3条评论
添加一条评论
2个答案
已选择的解决方案
@cullin Apple will not repair your phone since it was water damaged. You can try and have an independent repairer like @refectio take a look at it. You need to let us know what Apple charged you for. Was it for a repair (doubtful) or an evaluation? I doubt you'll get a refund but you can always try.
This "I dropped it in water 2 months ago and it is starting to overheat, battery expanding, turns itself off, and dying even when charging." is a good sign of what is really going on with your phone. Most likely your battery has finally failed. You did not tell us if you ever took care of the water damage or if you left it untreated. If untreated then this would be about the time I'd expect corrosion to set in and your battery to fail. As much as I despise Apple and other companies that treat consumers like they do, this may actually not be their issue. Open it up, clean it, replace the battery and then re-evaluate.
这个答案有帮助吗?
得分 4
6条评论:
Yeah, I took it to an independent repair store and they said there is a short circuit and corrosion, but will the phone completely die if the corrosion isn't fixed?
完成的
@cullin yes it will and may already have done so.
完成的
How long does it take to completely die from corrosion?
完成的
Days, weeks, month it all dpends. If may be corrosion it may be solides left by the liquid. There is no exact timeline as for when it shortens out component or corrodes pathways and solder pads. Hence the importance of cleaning asap instead of waiting.
完成的
Do you know how much it usually costs to clean it?
完成的
显示更多的1条评论
添加一条评论
Take it back to the Apple store, you paid them to repair it and it got worse. They likely shouldn't charge you again.
Worst case scenario get a refund.
这个答案有帮助吗?
得分 3
2条评论:
Is there a certain amount of days I have to go back and get my refund? Like some sort of warranty or something?
完成的
@kcrney. Apple will not repair this since it is water damaged. You will always pay for having them look at it and we do not know what the charge was for or high the charge was.
完成的
添加一条评论
添加你的答案
Cullin Roberts 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 134
