跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
299 个问题 查看全部
Can move icons around on screen, but can't press any buttons
This is a bizarre problem to have.
Did a screen replacement, using an OEM screen. Didn't have any problems with the repair and I checked all functionality before gluing it shut; there weren't any issues. However, now - as I'm trying to use it - the top of the screen (an area about 1.5" by 4", top left corner) won't let me push any buttons. I can move icons around in the affected area, but I can't press anything (like the "back" button in the Facebook app, for example). Why would the digitizer do that?? And is there anyway to fix this??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If you check your work is the digitizer flex fully plugged in and the latch closed?
这个答案有帮助吗?
得分 1
添加一条评论
Sound to me like one of two things,
#1 what ULOCK JOCKS said witch is the flex cable could be causing you some issues due to either minor damage from the closing up process or just came unseated.
#2 in that corner of no response there could be a very minor hairline crack in one of the digitizer panels which could also be causing this issue for you either way screen has to come back off in-order for any further trouble shooting to happen on your part. Good luck let us know.
这个答案有帮助吗?
得分 1
1条评论:
Yes that was what I was going to say next snaps man!
完成的
添加一条评论
添加你的答案
Grace Wong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 40
