Key fob stuck in ignition
Just replaced the battery in my key fob. I got into my car with the normal key, put the fob in the ignition and now it won't come out. Evidently I need to reprogram, but how can I get the key fob out?
Update (10/20/2017)
I realized my car battery was the issue. It was flatlined.
Left headlight was staying on even with key out.
So that seems to be the main issue.
I was able to get the key fob out after jumping the car.
So just trying to find a solution now for the headlight issue.
May disconnect headlight for now so it doesn't continue to drain battery.
3条评论
Try this
https://www.youtube.com/watch?v=m9GzBP_K...
由 macrobt 完成的
this worked for me omg thank you so much
由 aubz 完成的
Glad it worked, pass it along...
由 macrobt 完成的
