跳转到主内容
The B6 and B7 versions of the Volkswagen Passat are front-engine large family cars produced by Volkswagen, a German automaker. The B6 line of the Passat was produced between 2005 and 2010, and the B7 line was produced between 2010 and 2015 as a facelift of the B6 line.
27 个问题 查看全部
Key fob stuck in ignition
Just replaced the battery in my key fob. I got into my car with the normal key, put the fob in the ignition and now it won't come out. Evidently I need to reprogram, but how can I get the key fob out?
Update (10/20/2017)
I realized my car battery was the issue. It was flatlined.
Left headlight was staying on even with key out.
So that seems to be the main issue.
I was able to get the key fob out after jumping the car.
So just trying to find a solution now for the headlight issue.
May disconnect headlight for now so it doesn't continue to drain battery.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
this worked for me omg thank you so much
完成的
Glad it worked, pass it along...
完成的
添加一条评论
3个答案
最有帮助的答案
Push on brake and hit button forgear shifter a couple of times.
这个答案有帮助吗?
得分 2
3条评论:
Yes, I had tried this already but it had not worked for me.
I had seen a video showing that.
It would have been great!
Thanks
完成的
It worked for me. Thank you!!
完成的
添加一条评论
Its answer is pretty simple.
Move your car backward and forward again.
Make sure your handle face front. DO NOT LEAVE YOUR CAR WHEN YOUR WHEEL IS TURNED.
这个答案有帮助吗?
得分 0
2条评论:
I was programming my remote key fob now the fob is stuck in the ignition
完成的
I was programming my key fob and now the fob is stuck in the ignition I can’t get it out
完成的
添加一条评论
Is there a battery in the fob?
If the five won’t come out of the ignition?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Darby Rosello 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 93
总计 20,603
