跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
问题已关闭
Location Services "cannot determine location!" why?
Location Services "can determine location !" via wi-fi around public areas
but it "cannot determine location !" via my vista operating laptop with cellular 3g internet and microsoft security essentials installed.
Location Services are already enabled. But don't work.
can anyone help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Try this article and see if that will help you? Seems to be a setup issue, probably related to your Vista laptop setup. http://www.technipages.com/ipod-touch-ho... Good Luck
这个答案有帮助吗?
得分 3
6条评论:
thanks but it doesn't work
完成的
have you tried this http://cydia.pushfix.info/ or have you tried a Network Reset (in Settings)?
完成的
This didn't work too. I think there is a problem with the "microsoft security essentials" installed. I need help again.
完成的
Did you get your email back from skyhook? If so, turn off your firewall. The firewall is more than likely blocking the skyhook service.
完成的
I sent my location degrees and even pointed on the map but skyhook didn't email back after examining
完成的
显示更多的1条评论
添加一条评论
Try getting into the configuration settings for the Microsoft Security Essentials. There may be some sort of setting which might be causing the problem. The Location Services on the iPod Touch as you know, only works when the Wi-Fi is on, and I suspect the Microsoft security program might be preventing the location service from working. If this is the case, I suggest you uninstall the program and try again.
这个答案有帮助吗?
得分 0
4条评论:
sorry Jon. This doesn't work too.
完成的
Try going to a place that offers free Wi-Fi service; Starbucks is
one such example and try it there. If it works, then it might be some sort of security setting.
完成的
hi Jon it works with wi-fi services around but it doesnt work with my laptop with microsoft security essentials installed.
完成的
Try looking at your security settings. There may be some sort of setting that may be blocking the location service on your iPod. Otherwise, try uninstalling the program on your computer and try again.
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 7,258
