跳转到主内容
修复你的物品
维修的权力
配件 & 工具
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
5065 个问题 查看全部
I replaced battery with a battery that screwed up my phone
So i ordered a battery for my Iphone and replaced the current battery in it. As far as doing the replacement it went very smoothly. When everything was put back together I started up the phone and there were vertical bars across the screen and there was nothing about the phone that was working at all. When I took the phone back apart, i read the battery writing and both the WHR and the APN didn't match. It was then i realized i was sent the wrong part. I put back in the old battery and there was no change. Just bars across the screen. Is my phone salvageable? If so how do I go about fixing it or is there a way to at least get my files off of the device?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
2个回答
Can't say for sure but I would try another screen with the right battery. Hopefully the damage didn't go very far.
这个答案有帮助吗?
得分 0
添加一条评论
Normally, bars across the screen is lcd damage (or on the cable) possibly it's been damaged when removed.
As mentioned above, try a new screen, when you unplug the battery, hold the power button down a few seconds to make sure everything is "drained" of power inside the phone. I've seen this cure some issues before as well as home&power button reset.
Best of luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
elee4364 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 36
