跳转到主内容
修复你的物品
维修的权力
商店
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
180 个问题 查看全部
Can I repair a chip in the screen?
So ive just got myself the all-new MacBook Pro after spending more than 5 years with my 13 inch retina, but I've only had it a month yet theres already a chip on the screen. I'm Stupidly careful with my laptops, I've had at least 10 people say "you spend more time cleaning it than using it", my last laptop had one chip after four years of owning it. Anyone know If I can use any scratch remover for the glass or do I have to wait for a glass panel for it to come out? or could I maybe get it covered under warranty?
thanks!
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 4
评论:
Exact same situation. I've had mine for less than a month and there's already a small chip right in the middle of the screen. I'm also extremely careful with my laptop so I have no idea how this could have happened.
Did you bring it to the Apple store?
完成的
Yes, I did in the end. They couldn’t see the chip but I had a hinge problem and they replaced the whole screen. However, While replacing my screen they blew the speakers! After the screen was repaired I put a screen protector on it, and it seems to look really good. I got mine in matte which personally brings the pro quality of the mac back,
完成的
The service center blew the speakers while replacing the display assembly??? Wonder how that happened... They did fix it on their dime right?
完成的
添加一条评论
2个回答
已选择的解决方案
Hi Zac,
The screens have a coating on them so I would suggest against using a scratch remover as it will mess up the coating. I think your best bet would to bring it into the Apple store and see what your options are.
这个答案有帮助吗?
得分 6
评论:
Thanks Blake! if it's the coating that's scratched, can I get some sort of liquid coating that will brush over the top of it? (like the retina coating fix)
完成的
添加一条评论
Bring it to athe pple store and they will replace it for free. I’m working with a lot of MacBooks and every time I see a chipping one, I'm bringing it to the apple store and they're replacing it for free.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Zac Stojanovic 将永远感激不已
浏览统计数据:
过去的24小时: 12
过去的7天: 65
过去的30天: 327
总计 9,919
