跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
home button separated from LCD
followed the instructions to lift up the lcd to expose the battery but the battery did not get exposed instead the LCD separated from the home button and the metal cover laying on top of the battery. so the question: how to expose the battery without doing damage to the phone
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Olivier,
It sounds like the frame that secures the LCD display to the phone has become unglued. Unfortunately you may need a new LCD screen on top of your battery problems.
When trying to access the battery make sure you are using a suction cup or the iOpener to lift the screen, then use an opening tool to slide under the frame and lift it with the LCD in one piece.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
olivier zanen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 29
