跳转到主内容
Kenmore is a popular appliance brand commonly sold by Sears, but Sears does not manufacture any of the appliances themselves. Instead, they source that out and have other manufacturers make their appliances for them. Kenmore refrigerators are made by a variety of different manufacturers including LG, Electrolux, GE, and Whirlpool.
117 个问题 查看全部
Why is my refrigerator not cooling enough?
My LG model 795.7103 is 6 years old, and was working perfectly until 4 days ago.
The temp is set for 40 degrees-frig/zero degrees freezer, but now cools to 50 frig/35 freezer. It's as if it's stuck on defrost.
A name-brand repairman didn't find an immediate cause, even after removing freezer drawers and back-of-frig panels, and used his hand-held tester, and was on the phone with someone else much of the time.
The coils are free of ice. The compressor is running, and the air coming out is cold, but not icy cold.
The refrigerator has never been moved, so I'm doubting a seal broke.
He said he was unsure of the problem, and would have to open the closed system to look for leaks.
Parts and labor could cost up to $1500 and 3 trips to my house.
Thanks in advance for any suggestions.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
CAROLYN QUTAMI - Sadly, the repairman is right about the problem located in the sealed system. The price is different between companies. My area starts around $800 -$1200. Some of the sealed system parts might be covered under manufacturer's warranty. Contact LG customer support 1-800-243-0000 be sure you have the model & serial number off the tag inside the fresh food section. If you decide to repair it I would recommend LG handle the repairs or a qualified technician with LG experience.
这个答案有帮助吗?
得分 4
添加一条评论
Why is my refrigerator not cooling? sounds like a similar scenario. There is a lot of information and if you can see the parts that might be having trouble, it'd give you a place to start looking.
Good luck!
这个答案有帮助吗?
得分 2
3条评论:
You have very strange dreams. Is that a taco dog?
完成的
Mayer-your funny
完成的
I let out an audible laugh at this XD @mayer @alphapeaches
完成的
添加一条评论
I found a repairman who's very familiar with the LG refrigerators. Apparently they have a lot of compressors go bad.
He checked our unit and immediately diagnosed a faulty compressor.
I ordered a new unit online from Sears Parts Direct and he returned to install it the next week.
My total cost was around $600, not as bad as feared.
I still love that refrigerator and don't want to replace it; current similar models of any brand won't fit in the space.
Here's hoping it lasts another six years!
这个答案有帮助吗?
得分 1
1条评论:
Carolyn Qutami - LG's manufactures warranty on the sealed system - (compressor, evaporator, condenser, filter drier) covers parts and labor for 1 year then they cover the parts only for 7 yrs. The linear compressor is covered for 10 years. After the first year all you pay is the labor.
完成的
添加一条评论
添加你的答案
Carolyn Qutami 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 13,571
