跳转到主内容
Repair and troubleshooting help for the Memo Pad ME172V, a 2013 tablet manufactured by Asus.
16 个问题 查看全部
Broken Power Button After Dropping Tablet
So I dropped my tablet and now it won't turn on... I tried charging it and holding the power button but it won't work! Help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi,
Is the Power button literally broken or are you just saying that the tablet won't turn on when the button is operated?
Do you get any indication at all the the tablet has some functions working? For example, when the charger is connected, does the tablet show that it is charging
You may have to open the tablet and do an initial visual inspection, to see if there is anything obviously damaged due to the fall.
Here is a link to the Asus Memo Pad ME172V - LCD Display Replacement repair guide which should be of some help.
这个答案有帮助吗?
得分 2
2条评论:
When I charged it, nothing would show...
The power button was pushed in before but it still worked. It doesn't work/react now.
Doing both at the same time also doesn't work...
Did I mention that the screen is shattered?
I'm sorry if this information does not help much...
What should I do?
完成的
Hi LL Awesome,
Having a shattered screen is certainly not a good start. Presumably the tablet has been dropped
I suggest that you open the tablet as shown above and see what internal damage has occurred and progress from there as to what to do next.
完成的
添加一条评论
You're going to have to remove the plastic power button to see underneath and actually press it yourself
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
LL Awesome 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 2,983
