跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1505 个问题 查看全部
Battery not holding charge!
I changed the battery but it still does not hold a charge for more than a day. I have also noticed it would completely discharge. For example I use it as my alarm clock and the other morning the alarm went off and the phone died. This is confusing as it is not happening all the time. I hope it's not the logic board :-(
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
评论:
stevenoneil, which OS are you running, any recent updates and is your phone jailbroken?
I see you got some good people working on this :-)and I am not sure why you think it would be your logic board. Other than having a perceived short battery life there does not seem to be anything real wrong with it. I'd follow the instructions by pollytintop first and see if you can minimize the drain on your battery.
4.2.1(8C148) and no it is not jail broken.
添加一条评论
2个回答
已选择的解决方案
check you've turned off push notifications etc, turn off gps/location services for apps. If you have recently downloaded an app and then this happens try removing app/updating. Select screen save/power save settings.
What was your battery life like on a normal day before you changed the battery? Mine lasts about a day with normal use...
这个答案有帮助吗?
按维修分数 4
添加一条评论
Bad news to tell you it is the logic board, and it's drawing too much current. I'm still trying to work out how to repair it, I'd like to know what components need replacing if its possible too. Or else u can buy an extended battery case for your iphone.
这个答案有帮助吗?
按维修分数 1
评论:
No other options? straight to replace the logic board?
polly, he/she sounds like an Apple Genius - replace the logic board.
toto - how about some support for your conclusion? Any links?
添加一条评论
添加你的答案
stevenoneil 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 5,423
