Power supply for iMac retina late 2014
Which power supply should I buy ? Upper one or lower one ?
I linked below.
I linked below.
Hello,
You only posted one link... This part should be good as long and you correctly match the EMC#. You can put your serial in Everymac ultimate lookup to check you current models EMC#. Opening it up and replacing the PSU is the hard part.
BTW don't forget the Adhesive strips.
[关联产品丢失或禁用: IF174-005]
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 790
2条评论
As far as I can see, those are the same part. Perhaps you accidentally put the same link twice?
由 Rachel Acosta 完成的
Are you sure you need to replace the power supply? Double check your cord is good and review the diagnostic LED's what are they telling you.
由 Dan 完成的
