top half of screen dark
top half of screen dark, suggestions?
jeff bad backlight strip. Remove your power cord, then remove the back panel. The backlight is in behind the panel and since this is a Vizio, repair manuals are not easy to come up. You'll have to experiment or check youtube to see if you find a Vizio backlight repair. This video should help you out and this one is a general one on how to replace the backlight strip.
这个答案有帮助吗?
Where did you buy the the new back light strip ...?.?.
The Visio Support site helped me (via a google search). Do this before taking the extreme measures of opening up the unit:
Using the Visio remote, press the Menu button, then System>Reset & Admin>Soft Power Cycle>Yes. 20 seconds later I was good to go.
If you don’t have the Soft Power Cycle feature on your unit, you can unplug the unit from its power source, then press the TV’s power button on the side for 3 seconds, plug the cord back into the power source, then turn on the TV.
If this doesn’t work, there are other steps which were unnecessary for me.
这个答案有帮助吗?
I don’t have a power button on the tv. Vizio E700i-B3?
Thank you so much! This worked for me right now.
I tried this and it went to a very small screen on the upper left corner?? Fixer it by just turning off and turning tv but the dark shadow on top is still there. This is sooo frustrating
That worked for me too!!! Thank you!!!!
Dwhyink thank you!! That just saved us from having to open up the tv.
I tried these things (Unplug, reboot tv) & it didn’t work. Tried using my TV remote & watching from a different input besides cable tv, and it worked fine. No dark upper area. That told me that my cable was the issue. Rebooted my cable box per directions online and it fixed the issue.
这个答案有帮助吗?
过去 24 小时: 19
过去 7 天: 94
过去 30 天: 576
总计 71,273
7条评论
4/15/21 I had this problem too. I fixed it by unplugging the power cord then depressing the power button on the TV for 5-7 seconds. Plugging in the power cord and turning on the TV.
由 thomasklynchjr 完成的
Thank you! I woke up this morning to this issue. I have a 24 inch and found it does not have a on/off button, so I just unplugged it for about 5-10 seconds. Plugged it back in and I was good to go!
由 Charlton Norah 完成的
Holy F. SAME WITH MINE JUST NOW.
由 Eric 完成的
I tried these things & it didn’t work. Tried using my TV remote & watching from a different input besides cable tv, and it worked fine. That told me that my cable was the issue. Rebooted my cable box per directions online and it fixed the issue.
由 Kim 完成的
Same thing on my tv. Half dark. VIZIO. Unplugged wiped dust off tv then plug in again. It fixed the problem.
由 compwease 完成的
显示更多的2条评论
