跳转到主内容
Released Apr 2008. 7MP camera with 3X Optical Zoom.
21 个问题 查看全部
No power after trying two new batteries.
What else could cause the camera not to turn on?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
@walk biggest issue with this type of camera is the door to the battery compartment. If it does not seat properly or does not make proper contact, your camera will not get power. If that looks ok you will have to go ahead and disassemble your camera for further testing. Here are the guides to work on your camera. Follow the block diagram and measure the voltages as shown on it.
Your camera has three fuses and the one to check is F1 on the power board.
Let us know what you find.
这个答案有帮助吗?
得分 3
添加一条评论
Hi @walk, before that, is there any problems or issues from this camera,
you mentioned you had used new batteries, you tested and does the battery feel hot / warm when remove ?
这个答案有帮助吗?
得分 1
1条评论:
where can i take my camera to have it checked ou either in Silverdale or Lynwood WA?
完成的
添加一条评论
添加你的答案
Cheryl Walker 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 50
总计 1,479
