跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 个问题 查看全部
SSD in a newer 21 model MC508 or 509 LLA
Based on the threads here, I've noticed that it seems I cannot change the GPU in this machine.
That being said, can I run a second drive in this machine like the 27" models? I would like to run a SSD for boot drive and keep the factory installed HDD.
Any thoughts would be appreciated!
MM
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
There's no room or spare SATA input to do it on the 21" model.
这个答案有帮助吗?
得分 1
3条评论:
He'd have to sacrifice his ODD to do it
完成的
Ok then. How about if I replace the HDD with a SSD, then put the OEM HDD in an external case connected by Firewire? (I do want to keep my ODD)
完成的
That should work great. Or put the optical in an external firewire and use a hard drive adapter.
完成的
添加一条评论
添加你的答案
Mark M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,078
