After screen replacement home button hits 3/4 times
When I press the button, my iPhone vibrates 3/4 times.
This happened when I replaced my iPhone 7 screen with an original screen.
Can you help me with this?
This is most likely due to either the screw on the back of the home button being too tight/loose. If this is not the cause then it is probably a short in the home button.
这个答案有帮助吗?
I will try to make the screw lose. I let you know!
Not working :(
If that didn't fix it then the home button was damaged or isnt connected right. This can also be caused by using a Chinese replica screen that is not good quality.
Reinstall the home button or try anther home button to have a try.
这个答案有帮助吗?
If you use another home button, it wont work at all. Try using the original home button. If not then there isn't much you can do
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 84
