跳转到主内容
Guides and repair information for washing machines produced by Bosch, a German engineering and technology company.
21 个问题 查看全部
Stainless steel barrel loose
Stainless steel drum has come loose
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
@dionysius what model is your Bosch?
完成的
添加一条评论
1个答案
已选择的解决方案
What kind of sounds is it making?
If the sound is noticed ONLY at the end of the spin cyle:
*Thump-Thump-Thump-Thump*
This will be a worn Agitator Drive Block.
This repair requires some level of skill to correct (and possibly one specialty tool)
__________________________________
If the sounds occur DURING the spin cycle:
*Bang/Boom/Rattle/Etc*
This is most likely a tub assy that is not in it's proper position on the superstructure/frame and/or a missing suspension support spring.
To correct this--also requires a bit of previous experience being able to identifying whether or not the tub is out of position on the frame.
The rear spring however---if found hanging---is easy enough to correct with a drill unless the spring lacks a *hook* from corrosion.
Bottom line---this repair can be more than a DIYer wants to tackle. A competent servicer can resolve either fault rather quickly.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alistair Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 4,854
