跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
368 个问题 查看全部
Post LCD repair. 3D doesnt work properly.
Hi! I have a New 3DS XL and I recently repaired the top LCD by replacing it with the necessary OEM one. Now the LCD itself has its own issues, like a couple dead pixels and some color saturation. But my biggest concern here is that the 3d isnt working properly. With and without stable 3d on, the picture gives a 2d, very blurry image that worsens as the slider goes up, and stops when it’s low. What could be doing this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
Where did you get the part from?
完成的
You might have gotten grifted with a fake screen.
完成的
How do you think?
完成的
Well, an original part would have worked fine. What you could try, although I doubt it it will fix this problem is reseating all upper LCD ribbon connections.
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
@joeyw532 "the LCD itself has its own issues, like a couple dead pixels and some color saturation." is a pretty good indication that your screen is defective. Replace it once more with a known-good part and then reevaluate.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joseph M White 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 609
