苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3789 个问题 查看全部
Why my iPhone get overheated?
i have ios version of 10.3.3 in my mobile. when i play song or capture photo my battery percent decrease rapidly and get overheated. when i use camera for 4-5 min my battery decrease up to 30-40 percent and get overheated.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
3个回答
已选择的解决方案
The Apple Store won't help you, they will simply offer an OOW (out-of-warranty) replacement or suggest you upgrade the phone. That may be the right thing to do but if you just want to repair your phone, I would suspect you have a bad camera. You didn't specify which camera is affected or if it is both. If both cameras are problematic, I could point to a logic board issue. However, if it is one or the other, then I would open up the phone and disconnect that camera and see if the phone works well. Look to this page for guides on all of the components of the iPhone 5S.
这个答案有帮助吗?
按维修分数 3
添加一条评论
It is recommended to the Apple store to detect if there is a hardware problem with the battery
这个答案有帮助吗?
按维修分数 0
添加一条评论
Either a Logic board issue or battery. It could also be a faulty cam depending where you notice it getting hot . If its the back by the logic board probably something wrong with it. Could be a bad Battery or cam as well, or all the Above. Hard to Diagnose without it in front of me, but these are the parts I would try first , if replacing doesn't help then most likely the logic board, time to upgrade to a newer phone if that is the case. Hope this helps. Also, I agree with Minho apple will not attempt to work on this phone since its an older model now they will offer a trade in or something most likely, if not an out of warranty replacement. But I would start by seeing which part is overheating and then start replacing the parts .
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Shyam kexhy 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 2
总计 55
