跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2686 个问题 查看全部
Is it impossible to remove the home button flex cable in a 6s?
I know you can on the 6 but I've read it's fused to the digitizer in the 6s. Just looking for confirmation.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
The home button extension cable is together with the screen on the iPhone 6s.
The home button itself is separate and removable though.
这个答案有帮助吗?
得分 3
3条评论:
Ah yeah I meant the extension. My 6s is going through the "cannot activate Touch ID" thing and Apple told me my sensor is busted. So I was thinking if I could replace the extension cable, that might help since I know I can't replace the button itself.
完成的
If you happened to have replace the screen and then that message appeared then there is a chance that the cable (from the screen) plugging into the home button and logic board is faulty.
完成的
Thanks, Ben! So it may be worth just getting an entire display replacement to test that hypothesis out since I can't just replace the cable.
完成的
添加一条评论
You will have to replace the metal plate that has the flex extension in it. During screen removal, this cable is easy to stretch and subsequently damage. I did it on my first one and panicked because you cannot replace the Touch ID but turns out it was only the extension which is replaceable.
这个答案有帮助吗?
得分 0
3条评论:
The design of the home button extension cable is different from the 6 and 6s. On the 6s it's pretty much built together with the screen.
完成的
Hmm! I wonder then-- because I have a spare 6s display (cracked screen) that I wouldn't mind busting up to get to the cable. Think it's possible?
完成的
I'm not sure but it might be easy to separate that part on the screen. Not sure for original screens but some aftermarket screens make it easy to separate.
完成的
添加一条评论
https://www.youtube.com/watch?v=84NHEc5m...
I have used my cracked 6s home button extension cable to fix this issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,889
