跳转到主内容
The Samsung NaviBot SR8855 is a handy autonomous vacuum by Samsung.
19 个问题 查看全部
Why does my navibot dont switch on?the battery is charged, but no ligh
My navibot Doesn't switch on. The Battery is charged but all lights are off. I tried to Clean it but Nothing changes.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
最有帮助的答案
@doxdici you will have to disassemble it and take a look at all connectors and check the battery to ensure it is working. A dead battery may appear to be charged but does not hold a charge. Start off with this teardown Samsung NaviBot SR8855 Repair and take some pictures of what you encounter. Post those with your question so that we can see what you see. Use this guide 在已经存在的问题里加入图片 for that.
Use this diagram
to follow the power flow and see if there are any obvious damaged components etc..
这个答案有帮助吗?
得分 1
1条评论:
Where did you get this schematic?
完成的
添加一条评论
Your battery is not recognized by device it doesnt turn it self. You need to check battery 14.4-15.5 volt between
这个答案有帮助吗?
得分 0
2条评论:
Same probleme here, battery ok but navibot death, no lights, notting....! Switch is ok, voltage on the cirquit bord ok.
完成的
Are you sure with battery voltage? My battery shows 13.3 V and It`s new...
完成的
添加一条评论
90% switch on/off, it was very dirty contacts inside, you should change switch
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Doxdici 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 38
总计 3,087
