跳转到主内容
The DSLR D3100 from Nikon was released in August 19th, 2010. Features a 14.2 MP camera, Full 1080p HD movie, and a 3 inch LCD screen.
30 个问题 查看全部
Stuck polarizer filter on 18-105 lens
I accidentally overtightened an AmazonBasics CPL filter on my 18-105 Nikkor lens and it became stuck. How can I remove it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@niccotaglia you can try an force it off by using more force than you applied when you overtightened it. The other thing you can try is to place the lens in a plastic bad and place it in a freezer for a couple of hours. the cold will get the metal to contract slightly. Remove it from the freezer, give it a couple of minutes at room temperature, then apply enough force then try to remove the filter. The metal of the filter will most likely return to its normal state before the lens and should be easier to release. It would function like a shrink fit.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
niccotaglia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 124
