跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2689 个问题 查看全部
Auto Brightness settings missing after update.
I recently replaced my Front-Facing camera and Sensor Assembly and also updated to iOS 11 then to 11.0.1 and they moved Auto-Brightness. I found where they moved it to,
Settings> General>Accessibility>Display Accommodations
When I go there it is totally missing from the list. Does anyone else have this issue of it not being there? or is it possible that I just have a bad Front-Facing Camera and Sensor Assembly?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
You did make sure to click on display accomodations and not look for auto brightness on the accessibility page right?
Not sure what would make it disappear as the option should be there even if the front camera assembly is unplugged.
这个答案有帮助吗?
得分 1
3条评论:
Yes I did. I clicked on it and all it gave me was Invert Colors, Color Filters, and Reduce White Point. It should be in between Color Filters and Reduce White Point and it isn't there. It does say the following where it should be, Turning off auto-brightness may affect battery life.
This is a picture of what it looks like. https://photos.app.goo.gl/yx9aSWC97kDUiV...
完成的
Then it's probably a bad front camera assembly.
完成的
Thank you. Looks like I will need to get another.
完成的
添加一条评论
did you solve the issue ?
i have the same problem right now after i replaced my screen .
so if you solve it.. what is the solution ?
这个答案有帮助吗?
得分 1
添加一条评论
I replaced the front facing camera, ambient light sensor, speaker, and microphone cable. The ones I was getting from eBay were not OEM and didn’t work so I got mine from iFixit. That fixed my issue.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael Miller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,465
