Replacing the Logic Board with 2012 MBP LB?
Simple Question - Can anyone confirm that you can indeed take a 2011 15" MBP, remove the logic board, and insert a logic board from a 2012 15" MBP? If so, does it make any worthy difference (ie, performance, new features with OS, WiFi/BT) or is it simply too much work/effort?
3条评论
Exactly which boards are you planning on going from and what board do you want to go to?
由 mayer 完成的
Thinking of taking one like this:
MacBook Pro 15" Unibody (Early 2011) 2.0 GHz Logic Board
And replacing it with this:
MacBook Pro 15" Unibody (Mid 2012) 2.7 GHz Logic Board
由 Sean B 完成的
I would put the money into getting a bigger SSD drive than in a new logic board (if yours is still working)
由 Dan 完成的
