这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4553 个问题 查看全部
iPhone 6 screen dim and dark
My Iphone has a dark screen. I have tried to adjust the brightness, but it is stil the same.
Is is the Ambient light sensor defect or is it a defect LCD cable? I have also followed a guide of how to fic dim screen without open the Iphone, but it did not work. So it has to be a defect part, but I dont know which part.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 2
评论:
Can you explain a little more about your issue? When was it working last? What happened when it stopped working properly? Does Itunes recognize it? Can you still use it and it's just a dim screen with some backlight or do you need to put a flashlight to it to see the screen? Just a bit more history to make a proper suggestion on what you may be facing.
I bought it used. I dont know the history of the phone.
But everything works perfect, ecxept from the brightness.
Do you see the screen even though dim without having to flash a light on it?
Yes, the brightness is at its lowest.
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
3个回答
已选择的解决方案
could either be the screen or a bad component on the backlight circuit, possibly a coil
这个答案有帮助吗?
按维修分数 1
评论:
What is balcklight circuit, and where in the phone is it placed?
theres a few videos on youtube that could help you like this https://www.youtube.com/watch?v=PZE6R17n...
Thanks for the help
添加一条评论
最有帮助的答案
@djdannyrock is most likely correct then. If you have "Some" backlight, it is probably the coil as shown in pic. But if you are needing to flash a light on the screen to see anything, then I would start by checking continuity on the Filter first. If there isn't continuity, it needs changed. If there is continuity, check the caps shown in red (3 in a row) if good, then purchase the Backlight repair kit and change the IC, Diode, Coil and Filter all at once. IC and diode are also pictured with red.
这个答案有帮助吗?
按维修分数 2
评论:
So what do I do?
@wangton1 , If you don't have the experience or the tools for this repair, you have a couple options. 1. You can Google reputable local repair shops to find out what they charge and ask questions about the repair. Do they charge if they don't repair it? Do they have a warranty on their repairs, etc... 2. You can look here on Ifixit through the Pros and find one that does this repair through mail in service. Asking them the same type of questions. Most reputable shops do not charge if they don't repair it and offer a warranty on their repairs. The key is to shop around... From experience, I have seen ads from $50 up to $200 for the same service... just don't want to send it off to the first ad you find and end up regretting your decision :)
Thanks for the help :)
Anytime :) Best of luck!
添加一条评论
Settings > General > Accessibility > Display Accommodations > Reduce White Point > OFF
这个答案有帮助吗?
按维修分数 2
评论:
This helped me a lot thanks
You are most welcome.
This is what my problem was, but there seem to be several other causes.
Just found another cure for another dark screen problem:
Settings > General > Accessibility > Zoom > Zoom Filter > None
(or just Zoom > Off)
Thank you dear
You are a miracle worker! I did what you said above, and turned off my “reduce white point”as you directed, and my phone is so much brighter! I haven’t been able to see anything for quite a while. And I thought maybe because it was an older model, and iPhone 6s Plus. But this simple trick worked like a charm! I am so thrilled. Thank you so much for sharing your knowledge with others. Sincerely, Erin
添加一条评论
添加你的答案
Anton 将永远感激不已
浏览统计数据:
过去的24小时: 37
过去的7天: 236
过去的30天: 1,084
总计 20,098
