Rear wobbly wheel, and rim and tyre A1
2001 Range Rover P38
Fast or slow speed, rear off side wheel wobbles ! Tyre place checked wheel and tyre, balanced it again to no avail. Refitted and still wobbles !
@robinvanboxel check the wheel bearing as well as the hub. Check to make sure that your half shaft assembly is not worn out or bend or has a worn bearing. You also want to check all the bushings of your Panhard rod and radius arms.
This document may help you to get started on thisRange-Rover-P38-Rear-Suspension.pdf
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 194
