跳转到主内容
A 35mm FD-mount single-lens reflex camera introduced in April 1984 as the second in Canon's T series.
9 个问题 查看全部
Where to find replacement parts
How do I replace old parts on this older model camera?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hannah Bynum you did not tell us which part. This manual 1.EPS should have all that you need to repair your camera.
这个答案有帮助吗?
得分 2
2条评论:
It needs a new battery cover, off/on switch, and socket cover
完成的
Check for the numbers in the parts list in the SM. For example, the battery cover is part number CY1-1164-000 and available at places like this Not sure which socket cover you need but it might be part number CA4-1847-000 available at the same place.
完成的
添加一条评论
tenho uma toda funcional , prisma com muito fungo e lente um pouco o restante toda ok . se interessar….
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hannah Bynum 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 1,345
