跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
What's broken now? Apple screen loop
I replaced the logic board, hard drive cable, battery, and the hard drive with an SD card adapter. It restored and in disk mode was able to load music back on no problem. When I exit disk mode and try to use the iPod, it goes to the apple screen, turns off, and goes back to the apple screen, then turns off... over and over.
I don't really know what else I can replace, but figure someone here probably knows more than I do! The SD card reader is the iFlash Solo and the SD card is a 64GB card referenced as working on my model on the iFlash site.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Any ideas? I've tried opening the thing up and rechecking connections, but the issue persists - no backlight apple logo loop. I put it in disk mode to get it to stop while I "restore" from iTunes, then it starts the boot loop again. I've even tried using the old battery again, the old hard drive... tempted to try the old logic board again, but I know that wasn't working.
完成的
When using the SD reader (iFlash SOLO), the first reboot when plugged into a computer only displays "Please Wait. Very Low Battery." Using the original HD it boots up, but the HD is dying (noisy and it crashes after loading music).
完成的
添加一条评论
1个答案
After much diagnosis and parts swapping, I figured it out. The SD card got jacked up in formatting. Formatted it on a PC instead of Mac, then reinstalled and it all works!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John McPherson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 207
