跳转到主内容
My 2008 iMac won't recognize new SSD drive
My 2008 iMac won't recognize new SSD drive, reset NVRAM, and reset SMC no changed as instructed by Apple community, and even changed the battery. i know the SSD is good cause I have put and connect is to my MBP as an external drive and its recognized. are there any bios like window that i can config the mac to recognize the SSD drive. your assistance is appreciated. Wood56jam
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You need to use the original grey or retail versions of CD/DVD OS-X install disks or if you have setup an install USB thumb drive that will work too.
Keep in mind your system can only go up to Yosemite.
这个答案有帮助吗?
得分 1
添加一条评论
If you cannot access your SSD Drive try recovery of the drive using disk utility. Hold command + option + R until progress bar will appear. Choose the Disk Utility and format the new SSD Drive. Meanwhile, check out a similar Solved discussion. It might help you resolve the problem After installing, my SSD is not recognized after a reboot?
这个答案有帮助吗?
得分 0
1条评论:
simone,
This won't work as the drive is blank! And internet recovery is not possible either.
完成的
添加一条评论
添加你的答案
wood56jam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 417
