跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
274 个问题 查看全部
Cant format disk with OS Sierra Disk
Hi all, when trying to boot from my usb os x sierra drive i get the forbidden icon. This is the latest release and is not working. I cant find why this is not compatible. I also try with El Capitan. This is a Macbook Pro Retina 13" 2017 A1706 EMC 3163
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
How are you creating the USB OS X Sierra drive?
完成的
Are you booting your computer and then running the installer app? Have you created a bootable USB volume (e.g., via createinstallmedia)?
完成的
Im creating the usb with DiskMaker X, that makes the thing bootable
完成的
@sbotalla , use Sierra's own terminal command "createinstallmedia" to make a proper bootable USB. You need a working Mac with Sierra's installer app on it. See this article. https://lifehacker.com/how-to-make-a-boo...
完成的
添加一条评论
2个答案
已选择的解决方案
This machine requires a minimum of
Pre-Installed MacOS: X 10.12.5 (16F2073)
so El Capitan will not work.
http://www.everymac.com/systems/apple/ma...
UPDATE
Here's how to do an internet re-install on your machine: https://support.apple.com/kb/ph25649?loc...
这个答案有帮助吗?
得分 3
2条评论:
I tried with the lattest OS X Sierra available which is the one downloaded through Apple Store. Where can i get that version of OS X (10.12.5)? Thanks!!
完成的
@sbotalla, to get the latest (10.12.5), simply delete the .app for the Sierra installer you downloaded from the Apple app store. Then go to the Apple App store, and re-download the installer for Sierra. This will get you 10.12.5 installer.
完成的
添加一条评论
@sbotalla , if you have a fast WiFi connection, you can simply use Internet Recovery to format and reinstall to either the latest OS X for your Mac, or the factory version.
See https://support.apple.com/en-us/HT204904
'''Start up from macOS Recovery
macOS Recovery installs different versions of macOS depending on the key combination you press while starting up. Hold down one of these combinations immediately after pressing the power button to turn on your Mac. Release when you see the Apple logo or a spinning globe.
• Command-R
Reinstall the latest macOS that was installed on your Mac, without upgrading to a later version.1
• Option-Command-R
Upgrade to the latest macOS that is compatible with your Mac.2
• Shift-Option-Command-R
Requires macOS Sierra 10.12.4 or later Reinstall the macOS that came with your Mac, or the version closest to it that is still available.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Santiago 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 640
