The phone won't charge after battery overheating
the phone has stalled during use and the battery has overheated, when the charger is plugged in i get the message: battery alert... the battery temperature is abnormal,charging has been stopped.
Try leaving the device off for a day or so.
If it does not work:
Consider getting it repaired for a battery replacement. Remember to not play with it on for too long, turn it off if not playing and do not overcharge it.
这个答案有帮助吗?
I found a 1.1kohm dead rezistor on pcb near the battery connector ,i replaced and work fine.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 3,467
4条评论
@rosioaratudor Have you tried turning off your phone for a few hours until the battery is cool, and then turning it back on? and doing what you just did before?
由 Vinicius Lupas 完成的
Battery paused exceeded ideal temperature range
由 Nancy Campbell 完成的
Yes it has refused to turn on completely
由 Kadiatu Kabba 完成的
I have tried all the above questions
由 Kadiatu Kabba 完成的
