跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
No more rotation, compass, and health
Hello,
When I open the compass app nothing happens and just stays still
In the health app it doesn't detect my phone in devices
And my phone doesn’t rotate to landscape anymore
What could be the problem and how do I fix it please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Follow software suggestions made above.
But this sounds like the Gyro scope/ Pedometer is not working. It would require a board level repair.
这个答案有帮助吗?
得分 1
添加一条评论
There could be a few things that could be causing your issues
1) check for storage available on your phone? If your storage is full or over full it could cause all sorts of problems, its most common on the 8GB and 16GB units.
2) Check your iOS software version if it is out of date? If this is out of date then I suggest doing a Backup of the phone via iTunes ( make sure its up to date also) and then restore and update the phone. After done restore your iTunes backup to your phone.
(You can check both your iOS and storage by following : Settings > General > About. If you scroll down you will find all of the info for your phone.
Good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Muhammad Helmi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,180
