跳转到主内容
MacBook Pro 13寸显示器版本
9729 个问题 查看全部
How do I tear down and replace the Airport Wireless Card?
MacBook Pro 13" Unibody
Hi there!
I bought a refurbished MBP 13-inch 2.26 GHz (A1278) and I don't think it came with a wireless card (I think I got ripped!).
Bluetooth is working but my airport says "No Airport card installed".
Where do I check to see if there is actually a wireless card installed? And if there isn't one, is it possible to replace it? Does anyone know how?
Any help and advice would be greatly appreciated!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
James you have this question spread out over six questions now. Please try to contain yourself. Thanks
完成的
添加一条评论
2个答案
最有帮助的答案
The card, located in the upper display is probably fine. The wire to it or connecting to the logic board are the most likely suspects. Check your connections first. How's are the hinges on this machine?
Here's what it looks like: http://www.macpartsonline.com/922-8782-a...
Here's a video on the teardown: http://www.powerbookmedic.com/manual.php...
这个答案有帮助吗?
得分 2
3条评论:
Hi Mayer,
Thank you for your answer. I followed the teardown video, it was a little tricky but relatively straight forward. I managed to find the AirPort Card inside the Clutch Casing at the base of the screen in between the hinges.
The wire connecting the airport card to the mother board looks fine, I think it is connected properly. Also, the other end of that wire is connected firmly to the airport card.
I did see this however. There are two wires with gold endings attached to the airport card - are these the antennae? One of them is connected firmly, the other one was disconnected and loose. I tried to push the wire into place but it wouldn't stay. I ended up using electrical tape to keep it in place. This hasn't solved the problem, my macbook still says that the airport card isn't installed. But maybe this loose antennae is the problem?
完成的
Update...
After following (the AWESOME) video guides on this website, I totally tore down my mac this evening. I found the AirPort Card inside the Clutch casing... so it IS in there, I'm not crazy.
It looked ok, and the cables at either side were connected ok. BUT there were two wires attached to wireless card, I'm guessing from the gold colored tips to them, connecting to the circuit board, that these are the WiFi and Bluetooth antennae?? Anyone? 1 was firmly attached, the other was loose. I tried to connect the loose one but it wouldn't hold down.
Thoughts?
完成的
Check the connector to see if the pins are straight or broken
完成的
添加一条评论
If you do end up replacing the airport card, made sure the cable is oriented correctly when you plug it into the airport card or it can short out the logic board and the airport card. The U shape on the connector should be facing away from you.
这个答案有帮助吗?
得分 0
3条评论:
Thanks for the pointer Tony. I'll be sure to remember that!
完成的
Update...
Thoughts?
完成的
I'm going to attempt replacing the airport card in my MacBook Pro 13in Unibody this week. Is there a particular way to disconnect / detach the bluetooth and airport antennae?
I'm hoping they can be disconnected as easily as the numerous cable connections to the logic board!
Hopefully they don't need to be soldered on or anything like that.
Any pointers or advice would be greatly appreciated!!
Thanks.
完成的
添加一条评论
添加你的答案
James McGrath 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 20,562
