跳转到主内容
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
202 个问题 查看全部
Turns on, does not charge.
Charging port perfect condition. Tried another charging port and battery.
Only shows charging icon at top right of status bar while phone is on for a moment.
Seems like a charging circuit issue but I'm not sure if it's repairable.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
This faults actually happen when the charging ic is not working properly.Battery has four connecting pin among them bsi and btemp point is not working trace the track.
这个答案有帮助吗?
得分 2
2条评论:
Thanks for the answer I was thinking probably charging ic issue, I will trace down the circuit and post results if the charging ic needs to be replaced.
完成的
Okay, changed PM8843 power management ic, charging now OK!
完成的
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 839
