Gear iconx replacement battery
I have a brand new set of Samsung Gear IconX Headphones and the left earbud has a battery life somewhere around 15-30 minutes. The right runs as per the specs. I don't have a proof of purchase, so even though they are new and still within the warranty period, I can't send them to Samsung for repair or replacement and Samsung does not sell the battery.
I've been looking, unsuccessfully, for a replacement battery, so I could try to swap out the battery myself.
Does anyone know where to get a replacement battery?
Has anyone successfully done the repair?
Thanks.
Update (09/12/2017)
So, I went ahead and opened up the left earbud and it actually was surprisingly easy. The battery in it is a "Varta Cp1254 A2". It is a 50mah version, but Varta makes an "A3" version that is identical except that it is 60mah, so that seems like a logical upgrade. The only problem so far is that these batteries are pretty difficult to find without ordering in bulk from China. While I would definitely like to find 4 A3's, I have no use or budget for a minimum order of 1000. If anyone has any or can hook me up with a vendor, I'd definitely be interested in buying at least 4 of them. Thanks.
9条评论
How did you open the earbud
由 Daniel Adame 完成的
Anybody figure out how to open the earbuds yet? I have the same issue, only with the right earbud instead of the left.
由 Wade Cheek 完成的
Hi mate! Could you please tell me how to open it? Do you used special tool or something? I need to replace the battery of mine. I found a supplier which is like £7.00+ each if buying 5pcs. Thanks!
由 Rommel 完成的
hi rommel,
do you have any spare to sell? i need 2pcs since it hard to get in my country
由 Muhammad Talhar Samsudin 完成的
There is no official step-by-step on opening the earbud to replace the battery. Nevertheless, I found the following CN website providing detailed disassemble steps for IconX SM-R150
Hope it helps
http://www.52audio.com/archives/6905.htm...
由 Sau Koon Neo 完成的
显示更多的4条评论
