跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Laptop went from Mac OS X to OS 9. It tells me I need the OS X disc
Can't pinpoint how it happened but my system regeressed
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
What exactly do you mean by 'went from mac os x to os x' and what exactly does it say?
完成的
I turned the power on recently and the OS X loading screen comes up but before it finishes it goes to my blue desk top and only has the OS 9 version running. Then a remote install OS X window pops up, then the user login pops up and it doesn't work
完成的
添加一条评论
基本电子产品工具包
小工具包。却有无限可能。
Shop Toolkits
基本
电子产品
工具包
Shop Toolkits
3个回答
最有帮助的答案
Can you try booting while holding down the Option key? Do you get a choice of OS9 or OSX?
Failing that, try booting while holding down the X key. This is supposed to start up in OSX. Been so long, I don't remember if it works just with Boot Camp or also with OS9, but it's worth a try.
这个答案有帮助吗?
得分 1
添加一条评论
If you have a backup you may want to just wipe the drive and reformat.
这个答案有帮助吗?
得分 0
添加一条评论
Can you describe the "remote install OS X window"?
While you're running in OS9, can you open the Control Panels/Startup Disk window and choose your OSX installation there? If the "remote install" window is actually the Netboot window, this should fix that.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Phil Staggs 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 844
