跳转到主内容
The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
310 个问题 查看全部
home button not working but work if I jump the 2 prong
hi replace an digitizer of an ipad 3th and the home button is not working but if i jump the 2 gold prong where the home button make is contact the lcd open...
i tried an other home button and usb flex same problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hello, most commonly, the home button module on the digitizer is not aligned properly. It is important to check the orientation of how the old home button was installed on the old or original digitizer that was removed. If you have aligned it properly, I would highly recommend for you to order a new home button.
这个答案有帮助吗?
得分 1
添加一条评论
Check the bracket placement and that there's no adhesive over the edge keeping the button from sitting too high causing no contact.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Reparactif 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 69
