Battery charging issue, no blower
2000 Isuzu Trooper, heating/cooling blower on dashboard not working, battery light is on, battery won't charge.... but, got it to all work couple times by disconnecting battery cables, hooking them back up, battery sometimes charges, light goes out, blower works, but problem recurs again. Suspecting ECM or charging relay if I could find it. Any advice is appreciated, thanks!
4条评论
will the truck start and run ok and do the lights work ok ?
由 Jimfixer 完成的
Yes, so far it starts and the lights and everything else works. Thanks for responding.
由 Lawrence Hart 完成的
I ran the car with headlights on, battery slowly drained. When it got below 11 vdc car wouldn't start. It's not charging. Can anyone tell me where the charge relay is located? Can't find it, and there's no Haynes or Chiltons book for this model. Thanks.
由 Lawrence Hart 完成的
Haven't yet removed the alternator, been looking at this thread, lot of helpful info on it, some guys tried more than one alternator and still had the same issues, scroll down and check out what "mwolfe" says on a long post, he thinks it's the answer - if it's not the alternator. Another guy said yes to this method also.
https://forums.edmunds.com/discussion/86...
由 Lawrence Hart 完成的
