跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Phone doesn't turn on, shows apple icon
Hi,
Got a iPhone 6 and it was working, I just had to reinstall new firmware. The battery went dead and never been able to turn it on since, I've replaced the battery with one I know works as I've swapped them with another iPhone 6 and the battery from this non working one works on there and 3utools shows it's a good battery.
However I when I try and turn it on all I get is the apple logo then it goes off. I've left it to charge and I've plugged it into the usb and done the power button and home button and it still only shows the apple logo.
I need help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Try a minimum system configuration, leaving only the necessary hardware.
It's unlikely but something might be tripping the phone out.
As I say unlikely but worth a go.
完成的
Tried that and still doesn't do anything.
Thanks though
完成的
添加一条评论
3个答案
已选择的解决方案
Hi Jaymie. Looking at the previous answers and your follow-up comments, you clearly have a logic board issue. This will require some micro-soldering rework and is not a DIY fix unless you have access to the right tools, schematics and skills/ experience.
Look locally for a reputable shop that does micro-soldering repairs. Ideally, you want to find someone local but good workmanship trumps locality. If you can't find one locally, then consider mail-in repair. There are several reputable micro-solderers patrolling this forum.
这个答案有帮助吗?
得分 1
添加一条评论
Press the home button and the power button and hold for five or 10 seconds and release it should go to recovery mode.
You may also want to try reseating the battery to make sure it has a good connection.
Abbot
这个答案有帮助吗?
得分 0
1条评论:
Unfortunately didn't do anything.
完成的
添加一条评论
You may need to restore your iPhone on 3uTools.
Please refer this tutorial: http://www.3u.com/tutorial/articles/1857...
这个答案有帮助吗?
得分 0
2条评论:
I can't use 3uTools as the phone doesn't stay on long enough.
完成的
What do you mean you can not use 3uTools?
完成的
添加一条评论
添加你的答案
Jaymie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 112
