跳转到主内容
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
phone speaker volume extremely low even with volume up to maximum
external speaker barely audible with volume control up to max. Can't hear phone calls, media or ringtones or alarms. just started this problem a few days ago. phone is barely a year old if that. Z981 from MetroPCS
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 20
10条评论
After increasing all volumes to max and still low hearing then Clean the small slot on the face of the phone at the top. Just besides the selfie camera. First rub with damp cloth and with a dry cloth hard. This is your call speaker. Bottom of the phone is media speaker.
完成的
Thank you so much! I thought I needed a new phone!
完成的
@longtall Thank you! This really helps a lot !! :D
完成的
You're the best. It worked
完成的
Bull Hockey. First Reboot Your Phone. Then Adjust Volumes A Few Times Until Sound Previews Are At Full Volume.
完成的
显示更多的5条评论
添加一条评论
4个答案
已选择的解决方案
check the speakers are clear they often get dirt or lint in them from your pocket and it kills the volume same can happen to the mic
这个答案有帮助吗?
得分 13
1条评论:
How do I do that
完成的
添加一条评论
if after all the things you tried then its time to buy some ifix it tools and order a new speaker part and replace old with new and see if it works.
这个答案有帮助吗?
得分 8
2条评论:
it's my phone. has no volume at all it's on high as it can go and my phones speaker dos not working
完成的
im not buying a new one
完成的
添加一条评论
Mobile speaker skeling and speaker power
这个答案有帮助吗?
得分 2
添加一条评论
My phone is to quiet
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeff W 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 49
总计 189,518
