Why does my Samsung Galaxy J3 turn green on half of the screen?
I dropped a glass onto the back of my phone and now when i turn it on half of the screen is green/black and the other half is dimmed, is there a possible fix for said scenario?
It may possibly be that the connector to the digitizer was loosened by the contact or it could be that you damaged the digitizer with the contact. I would probably take it to a place for replacement or to check the connection or you can tear it apart yourself. I personally would attempt to do a tear down on it and check the connection first it will save you some money if it is just the connection. But sounds like it is a bad digitizer. It is replaceable you will just need to do some research on finding the part for the replacement.
Hope this helps.... [[ 无效部分链接 ]]
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,361
