跳转到主内容
An Android smartphone produced by Samsung released in January 2017.
20 个问题 查看全部
How can I uninstall system software updates?
I do not like the new update for my phone and would like it gone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I had the same issue with the proximity sensor failing with Android 7 so I rolled back using Odin and android 6 stock firmware
完成的
添加一条评论
4个答案
最有帮助的答案
Here are instructions on the 2016 A5 downgrade.
http://www.stechguide.com/downgrade-gala...
You need to find the 2017 stock image to downgrade.
What I don't know is if this will trip a Samsung KNOX security error.
IF you trip KNOX, you have voided your warranty.
If you are not worried about warranty, carry on.
这个答案有帮助吗?
得分 2
添加一条评论
Unfortunately, you cannot downgrade an android phone once updated. If you tell us your problems with the latest OS we may be able to work them out.
这个答案有帮助吗?
得分 1
7条评论:
I lost all my emails in the notes and personal since my update this morning 3/24/2018. I want it to be put back on today
完成的
@cschupp2012 Your emails are not stored on the phone itself. They are stored in the "cloud". All you need to do sign back into your Email account on that phone and they will return.
完成的
what about the notification badge? my messages badge does not appear only a notification at the top of the phone. also the badge goes away if i swipe notifications. so now i have no idea when i have an unread email, text or app notification. any help on this?
完成的
My phone updated today and I want to be able to attach different notifications sounds to individual contacts and it's gone! Can I get that function back?
完成的
@strawberrysteve It varies based on the phone, however, in general you can do this from the contacts app. Go to you contacts app, select the contact you'd like to change the sound for and click edit. The edit button typically looks like a pen in one of the corners. On that page, scroll down to the ring tone and notifications settings, and change as desired. Hope this helps!
完成的
显示更多的2条评论
添加一条评论
My incall volume is very low.I have done the obvious troubleshooting but to no avail.any help would be appreciated.
这个答案有帮助吗?
得分 1
1条评论:
Peter please open a new question on this. This is a solution section and your question will be buried here.
完成的
添加一条评论
Yes I agree with this statement. Anyway android is good enough in all the Functions, But not in all of the fucntions. Learn more latest trends. Home lifts
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kago 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 9,547
