跳转到主内容
Mac Air late 2010 does not turn on
Power Adaptor is connected, charging is normal (orange light is lighted on the adaptor connector).
No signs of life and no welcome chime after I press Power button, except for the cooling fan turning on after a minute.
PRAM reset (Command-Option_P-R keys pressed) and SMC reset (Shift-Option-Command-Power on buttons depressed then released) have not helped.
Any other ideas, guys?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Review this Apple T/N: Apple Portables: Troubleshooting MagSafe adapters
An Orange MagSafe LED that never turns Green often implies the battery is not charging. It also can be a bad battery as well.
这个答案有帮助吗?
得分 1
4条评论:
Orange light turned green after 2 hours. So it's a good battery and charger.
完成的
Can you give us some background here on what this system has encountered. Like did it get a bang or get wet as some point? Was the system running and then shut it's self off?
完成的
I last used the laptop 2 weeks ago and kept it in the storage drawer.. Now, it is kaput. No one touched it for the duration it was stored.
完成的
Dead systems on the most part need one to test for voltagages from the battery to the different power rails on the logic board.
You'll need access to the schematics, can read them, as well as have the needed tools to probe the logic board. For most, this is beyond a DIY job. Sorry :-{
完成的
添加一条评论
添加你的答案
Bernie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 815
