跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iPhone works, but battery won't charge up unless I bump it.
So this one's weird, had this issue for a while now.
My iPhone 5S after doing repairs on it, seems to have this problem where the battery will not charge. ( Lightning bolt and charging indicator is showing, but % will not increase when plugged in. )
However, if I bump the phone, it'll start to charge again until go about my day (carrying it in my pocket)
I've had this issue for a couple years now.. but it seems to have become worse..?
I'm able to see whether the battery is charging with an iPhone tweak called 'Battery Life' telling me whether the battery is receiving mAh charge input or not.
So yeah, bumping my phone is the temporary fix to make it charge.. what is the reason for that?
Obviously it's hardware related..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hello,
If you plug in the cable does the metal part completely go in?
If not its possible theres alot of dust in it blocking the power.
But when it indicates that its charging then it most likely is a motherboad issue. ( power ic lose or needing to be replaced) i would first try with a different battery and ligthing charger to be sure.
这个答案有帮助吗?
得分 0
2条评论:
Let's skip dirty charging port, cables and batteries and stick with the phone internals here. ;x
LOGICboard is fine, as far as I see. No damage and all screws not overtightend to print breach.
How is the IC 'loose' isn't that a chip on the board..? Unsure how a bump would change something so fragile and light weight.
Whatever it is has to be heavier.. could battery position dictate this?
完成的
no battery position should have nothing to do with this, my money is still on motherboard ive these kind of things before. A phone didnt charge if you held it, put if you lay it down on a table it works. This was also power ic.
完成的
添加一条评论
i think, the U2 USB charge IC or 1610A1 ic fault,
need check the current by multimeter
这个答案有帮助吗?
得分 0
1条评论:
D'no how that's got to be the issue, a bump of the phone changing whether something like that works or not?
Can't be.
完成的
添加一条评论
添加你的答案
Sumona Florence 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 129
