Updating my 13" 2.9 GHz MacBook Pro with an SSD
I have a 13" MacBook Pro 2.9 GHz i7 (Build 13F1911) that I want to install a SSD drive to make it faster.
Is it worth the upgrade and if so, is there a installation tutorial for it?
Update (09/04/2017)
I do have the 15" though... is it the same procedure?
8条评论
The build number is the MacOS version the system is using.
由 Dan 完成的
This is it. MacBook Pro 13" 2.9 GHz i7 (Mid-2012)
由 genik 完成的
Big difference :-}
由 Dan 完成的
Of course it is. You might want to change your question so that we can put in the correct machine.
由 mayer 完成的
Let's do this can you take a screen shot of the About Ths Mac window which shows the systems specs.
I don't remember Apple ever offering a 2.9 GHz 15" non retina system. The best we have are 2.6 GHz. I vaguely remember they had talked about it but I don't think it was ever sold. Here's the specsheet from Apple: 15" MacBook Pro 2012
As to the procedure it's basically the same but a different cable if you have the non retina model. The retina models don't offer HDD's they only have blade type of SSD (custom Apple part)
由 Dan 完成的
显示更多的3条评论
