跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4685 个问题 查看全部
Why is screen working on its own?
Basically, I bought a second hand iPhone 6, and when i first got it i noticed a few letters on the keyboard would press themselves, this progessively got worse to the point where i couldn't use the phone as it would just glitch out and have control of the screen. I ended up replacing the screen and yet it was the same when i powered the phone up. I decided to remove the lcd shield and turn the phone on with assistive touch and to my surprise the screen seemed to beworking fine. This is when i realised i hadn't removed the purple sticker on the back of the new screen. thinking it must be that, i put everything back together. To my dissapointment, the problem persisted. Could it be a faulty screen, the lcd shield is somehow messing with the screen or something else entirely?
Hopefully someone out there has a solution because im really dissapointed at the moment.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
3个回答
已选择的解决方案
It seems like the general consensus is its a digitizer issue. Either a bad digitizer, a damaged digitizer cable or connector, something pinching or caught in the flex cable area. My suggestion would be to open it back up after powering it off, disconnect battery...then remove all flex cables. Look carefully at both sides of connector for either debris or damage. If none, reconnect and power on...see if problem still exist or went away while gently holding phone in open position (like clam) . Just be careful not to connect or disconnect anything with phone powered on. If you can get it working that way, power off, close it...power back on and see if it's still ok. Personally, I believe it's in the digitizer cable or connectors...or even a ground issue...But in some cases the lcd and digitizer assembly just need changed.
这个答案有帮助吗?
按维修分数 4
添加一条评论
Clean the connector with alcohol and check whether the pins and connectors are in good condition.
这个答案有帮助吗?
按维修分数 0
添加一条评论
Replace the Digitizer/LCD Assembly and it should fix the issue. If a new Screen assembly doesn't work then could be a problem with the Logic Board. Or make sure the Cables are plugged in right for the digi on the current screen.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Stephen Kelly 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 19
总计 631
