跳转到主内容
The PowerBook G4 Titanium Series was initially announced at Steve Jobs' keynote at MacWorld Expo in January 2001.
130 个问题 查看全部
cant find bootable devices even pressing "C" or "ALT" key
PowerBook G4 a1138 cant locate bootable devices even i press key "C" or "ALT key" on startup. I tried also connecting an external optical drive to boot from G4 recovery CD but it only display "QUESTION MARK AND FOLDER". anyone knows to solve this problem??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
The question mark means it can't find a system folder. Use the original installation system disk and boot with the disk in holding down the "C" key. Gray disks made for other Macs will not work. Retail system disks will up to about 10.4. You can also access it in Target mode if you have another Mac. Your hard drive has probably failed but first please tell about the CD/DVD disks you are attempting to use.
这个答案有帮助吗?
得分 2
1条评论:
UPDATE Do you have the original installation disks for this machine? What DO you have?
完成的
添加一条评论
,i used the iBook G4 MAC OS X installation CD to install MAC OS X 10.4. Would this be the problem? thanks for immediate response.
这个答案有帮助吗?
得分 0
1条评论:
As you can see from the results, the iBook (Gray disks) will not work on your machine. They are machine specific so Apple can sell more Retail system disks. What other system disks do you have available? P.S. have a doctors appt and will be back about 3 if you can wait.
完成的
添加一条评论
Thank you for the information.... what system nstallation CD or restoration CD do i need so that i can re-install MAC OS in this powerbook?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cled Tayamen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,515
