跳转到主内容
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
133 个问题 查看全部
Fixed a Battery on my own, now the touch screen isn't responding.
I recently tried to fix this tablet on my own, at first it didn't work and there were some graphic errors(messed up colors and it wouldn't load properly, etc.) I decided to go back to strengthen the ribbons, thinking I might have put the ribbons protecting the battery too loosely. After I did that, it seemed to work. The screen was vibrant and looked normal, and you can see notifications pop up. However, now the I cant use the touch screen. I cant open the lock screen. I know it's not frozen because I do see email notifications pop up.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I just had a similar problem with my Iphone 5s. I don't know much about the Samsung Galaxy Tab 2, but I learned today what might be the problem. The leads on that allow the touch screen to work might either have some "fluff" around them or there could be a few missing as well. Best of luck to you.
这个答案有帮助吗?
得分 1
2条评论:
So I should open it up to check if something got inside the tablet?
完成的
Try just cleaning out by the leads, but be careful not to pull any out or bend any of them
完成的
添加一条评论
when you fix the screen you must power down first. You also must unplug the battery. Try cycling power by unplugging the battery for 1 minute then reinstalling
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jordan Shluker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 7
总计 87
