How do I fix the brake lights. left side
How do I change the brake light on the left side of my truck
If switching bulb to other side verifies bulb is Ok,
Or simply using test leads to truck battery -
Then you'll more than likely have fuse problem,
This panel might be in engine bay, if not inside cab.
The user manual will have location for fuse.
Note:
By Chance , was a trailer used recently?
I've seen this being the case many times,
The lead on trailer, or socket is damaged.
Blows the fuse.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 38
I don't know how to even take the light covering off
由 Joyce Makua 完成的
